[Gdal-dev] Problem getting ECW SDK 3.1 working with gdal
Brent Fraser bfraser at geoanalytic.com
Thu Apr 7 14:57:17 EDT 2005
Thom,
  You're likely right, I probably did a few other things (my memory has no
parity!).
>From reading the Microsoft page, it appears you would be ok  installing the
Windows 2003 Server SDK since is says it supports Windows XP, but I had to
read it a couple of time to be sure!
I did a search of my copy of the ECW SDK and I see that I commented out the
following at line 348 of Source\C\NCSUtil\malloc.c:
#ifndef _WIN32_WCE
// HMODULE hLib = LoadLibrary(TEXT("kernel32.dll")); //BWF
// if(hLib) {
//  FARPROC pProc = GetProcAddress(hLib, TEXT("GlobalMemoryStatusEx"));
//  if(pProc) {
//   MEMORYSTATUSEX MemoryStatus;
//   MemoryStatus.dwLength = sizeof(MEMORYSTATUSEX);
//   pProc(&MemoryStatus);
//   nTotalPhysicalMemory = MemoryStatus.ullTotalPhys;
//  FreeLibrary(hLib);
#endif // _WIN32_WCE
Although I'm not sure if that's necessary.  I'll try to do a fresh compile
with GDAL 1.2.6 (cvs tarball 20050405)
Brent
----- Original Message -----
From: "Thom DeCarlo" <t.r.decarlo at larc.nasa.gov>
To: "'gdal-dev'" <gdal-dev at remotesensing.org>
Sent: Thursday, April 07, 2005 12:21 PM
Subject: RE: [Gdal-dev] Problem getting ECW SDK 3.1 working with gdal
> Hi Brent,
> Well, I'm not sure that's all you did.
> I'm using:
> NCSSource_3.1rc1_18Feb05
> WinXP SP2
> XP SP2 Full Platform SDK
> VS.Net 2003 (Version 7.1.3088)
> .NET Framework 1.1 (Version 1.1.4322 SP1)
> The only Core SDK that I found seems specific to Windows Server 2003. I'm
> hesitant to install this on my XPSP2 computer. Is there any danger here? I
> haven't installed it and that might be why I still cannot find winhttp.h
> anywhere on my computer.
> Frank wrote:
> > I believe winhttp.h is part of the MS Platform SDK which you need
> > to download.
> > I think the build.txt in the ECW SDK directory talks about this a bit.
> Build.txt does indeed mention the Platform SDK, but only in the section
> referring to Visual Studio 6. That's why I didn't install it initially.
> Thanks,
> Thom
> Thom DeCarlo
>               Experience is a wonderful thing
> It allows you to recognize a mistake when you make it again.
> > -----Original Message-----
> > From: Brent Fraser
> > Sent: Wednesday, April 06, 2005 5:49 PM
> > To: Thom DeCarlo; 'gdal-dev'
> > Subject: Re: [Gdal-dev] Problem getting ECW SDK 3.1 working with gdal
> > Thom,
> >   I'm successfully using:
> >     GDAL 1.2.6
> >     NCSSource_3.1rc1_18Feb05.zip
> >     VS .Net 2003
> >     MicroSoft Platform SDK
> > Download the Core portion of the MicroSoft Platform SDK:
> >     http://www.microsoft.com/msdownload/platformsdk/sdkupdate/
> > Edit GDAL's nmake.opt to include the path to the Microsoft SDK:
> > INC = -I$(GDAL_ROOT)\port -I$(GDAL_ROOT)\ogr -I$(GDAL_ROOT)\gcore \
> >   -I$(GDAL_ROOT)\alg -IC:\PROGRA~1\MIFD68~1\include
> > I think that's it...
> > Brent Fraser
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
