[Gdal-dev] gdal_merge.py on OSX
Mike Logan mlogan at mail.arc.nasa.gov
Tue Apr 12 15:31:28 EDT 2005
worked great.  thanks, Frank.
ml
On Apr 12, 2005, at 11:51 AM, Frank Warmerdam wrote:
> On Apr 12, 2005 2:46 PM, Mike Logan <mlogan at mail.arc.nasa.gov> wrote:
>> Hi, I am unable to run gdal_merge because its choking on
>>         import _gdal
>> which doesn't seem to exist?   This is CVS as of yesterday afternoon.
>> gdal-1.2.1  doesn't seem to import this file.
>> Any clues for us clueless?
>> BTW, as a side note,   the pymod/  module in general still doesn't
>>   link in OSX, but I removed the -rpath from the GNUmakefile and
>>   it built fine.    I was getting the undefined symbols before like
>>    _PyArg_Parse, etc..
> Mike,
> I configure "--without-libtool" on MacOS X in order to get
> the python stuff to work.  If you end up installing the GDAL
> pymod stuff somewhere other than the default, you will
> likely need to set your PYTHONPATH environment variable
> appropriately.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
Michael Logan
QSS Group,Inc./NASA Ames Research Center
Task Lead,                 Visual Cueing & Simulation
Computer Scientist,  Adaptive Control Technologies
MS 262-6,
Moffett Field, CA, 94035
  (650)-604-4494
