[Gdal-dev] ogr2ogr little patch delete feature
Julien Demaria dem at acri-st.fr
Thu Apr 14 09:33:10 EDT 2005
Is OGRFeature::DestroyFeature better than delete feature ?
@@ -758,41 +758,44 @@
          CPLErrorReset();
          poDstFeature = OGRFeature::CreateFeature(
poDstLayer->GetLayerDefn() );
          if( poDstFeature->SetFrom( poFeature, TRUE ) != OGRERR_NONE )
              if( nGroupTransactions )
                  poDstLayer->CommitTransaction();
-            delete poFeature;
              CPLError( CE_Failure, CPLE_AppDefined,
                        "Unable to translate feature %d from layer %s.\n",
                        poFeature->GetFID(), poFDefn->GetName() );
+            delete poFeature;
              return FALSE;
          if( bPreserveFID )
              poDstFeature->SetFID( poFeature->GetFID() );
          if( poCT && poDstFeature->GetGeometryRef() != NULL )
              eErr = poDstFeature->GetGeometryRef()->transform( poCT );
              if( eErr != OGRERR_NONE )
                  printf( "Failed to transform feature %d.\n",
                          (int) poFeature->GetFID() );
                  if( !bSkipFailures )
+                    delete poFeature;
                      return FALSE;
          if( poDstFeature->GetGeometryRef() != NULL && bForceToPolygon )
              poDstFeature->SetGeometryDirectly(
                  OGRGeometryFactory::forceToPolygon(
                      poDstFeature->StealGeometry() ) );
