[Gdal-dev] Link errors with Ilwis in MS dotnet SDK
Delfos, Jacob
jacob.delfos at maunsell.com
Sun Apr 17 20:04:11 EDT 2005
Frank,
Thanks for that explanation. I'll give compiling php_mapscript a shot (even
if it's a long one).
Jacob
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
Sent: 15 April 2005 22:59
To: Delfos, Jacob
Cc: gdal-dev at xserve.flids.com
Subject: Re: [Gdal-dev] Link errors with Ilwis in MS dotnet SDK
On 4/14/05, Delfos, Jacob <jacob.delfos at maunsell.com> wrote:
> Hi Frank,
> I'm using:
> - Microsoft .NET SDK (which contains the core items such as nmake)
> - Microsoft Platform SDK for Windows XP SP2
> - microsoft Server 2003 PSDK
> - Microsoft Visual C++ Toolkit 2003
> I know it seems weird, just that neither one of these SDK's contains all
> utilities/files required to compile. It's a nightmare of
missing/conflicting
> .h, .obj, .exe and .lib files. Took me many days to sort out. I don't
blame
> you if you wouldn't want to tune gdal to it.
Jacob,
Well, I would like things to work smoothly with visual studio .NET 2003,
but without it this can be hard.
> I did a clean compile (using the original package files), but Ilwis still
> wouldn't work. But without Ilwis, gdal compiles and links completely
(after
> making the python dir a non-existing one). The executables in "apps" work
> fine with the new gdal12.dll. But php_mapscript (versions 42 and 44)
doesn't
> like the dll. Although when I compiled gdal125, php_mapscript worked fine
> with it. Has anything changed? Can gdal normally be compiled independently
> from php_mapscript?
My understanding is that php_mapscript would normally have C++ OGR
calls which have very specific signatures. You cannot generally use
a different version of gdal12.dll with it, because these signatures change
fairly frequently ... often for "const correctness" changes. In short,
anything
that depends on the C++ API of OGR (or GDAL) will tend to be "version
fragile". I would eventually like to migrate MapServer to use the OGR C
API which doesn't generally have this problem, but I haven't had time
so far.
So, I think you are basically out of luck replacing a GDAL 1.2.5
DLL with a newer one for use with php_mapscript. You either need
to build php_mapscript yourself (likely quite a job) or gently / financially
encourage DM Solutions to produce a more current build of the full
system.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | Geospatial Programmer for Rent
