[Gdal-dev] NITF transformation problem
Frank Warmerdam
fwarmerdam at gmail.com
Mon Apr 18 09:38:19 EDT 2005
On 4/15/05, Peng Gao <pgao at esri.com> wrote:
> > I'm a bit confused. The Geotransform is only six doubles long. Is
> > it GetGeoTransform() that is returning the above values? If so,
> > why do you get eight values? Does GetGeoTransform() return
> > CE_None?
> Sorry. It's 6 zeros, and GetGeoTransform returned CE_NONE. I don't have
> nitfdump. Here is the output from gdalinfo:
Peng,
I think I would need the file in question to further investigate. If
GetGeoTransform() was returning CE_None it "thought" it has some
sort of valid georeferencing.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
