[Gdal-dev] IsProjected and IsGeographic
Frank Warmerdam fwarmerdam at gmail.com
Wed Aug 3 22:47:15 EDT 2005
On 8/3/05, Craig Miller <craig.miller at spatialminds.com> wrote:
> Frank,
> I just wanted to verify that my code isn't going to fail on some oddball
> case.  :-)  Is it always true that if an SRS is not Geographic that it will
> be Projected and that if an SRS is not Projected that it is Geographic?
> E.g.
> Assert(
> (OGRSpatialReference::IsGeographic() == FALSE &&
> OGRSpatialReference::IsProjected() == TRUE)
> (OGRSpatialReference::IsProjected() == FALSE &&
Craig,
Currently there is also a third type of SRS indicated by the IsLocal()
method.  In the future there may be additional types such as a compound
coordinate system (one that defines the vertical datum).  So, no, it is
not wise to assume that a coordinate system is either projected or
geographic if you wish to operate with complete generality.
Best regards,
