[Gdal-dev] eosat fast format
Frank Warmerdam fwarmerdam at gmail.com
Thu Aug 4 13:15:23 EDT 2005
On 8/4/05, Sabine Grabner <csab7771 at uibk.ac.at> wrote:
> hi,
> i work with gdal version 1.2.6.0 released 2005/03/13 and want to read landsat7
> level1G data which i have as eosat fast format.
> surprisingly gdal_translate help does not say anything about supporting eosat
> fast format.
> hence i looked to gdal/frmts/fast/. this directory is empty.
> can you please help me to fix this problem?
Sabine,
The EOSAT Fast Format driver is named FAST and now lives
in gdal/frmts/raw.  It should be built in by default.
Best regards,
