[Gdal-dev] gdal with ecwsdk 3.2
Ken Sewell
sewell at dramail.com
Fri Aug 5 10:17:48 EDT 2005
Thanks, Bill. All it needed was the -DLINUX and -DPOSIX.
Ken Sewell Defense Research Associates
Project Engineer 3915 Germany Lane, Suite 102
937-656-4899 x3004 Beavercreek, Ohio 45431-1608
On Thu, 4 Aug 2005, Bill Binko wrote:
> Ken,
> Frank is on top of this, and we're hoping for a new build of ECW 3.2 that
> solves most of these issues.
> I'm sure he can get you a config that works.
> You might(!) get away with adding -DLINUX -DPOSIX and -DUNICODE to the
> build command line -- it has worked before.
> Other than that, I'll wait for Frank's response.
> Bill
> On Thu, 4 Aug 2005, Ken Sewell wrote:
> > Answering my own question. It seems a simple replace of libNCSE* with
> > libecwj2.so is all thats needed in the configure script. Also in the ecw
> > directory you need to do 'ln -s Source/include .'
> > This gets it so that GDAL mostly compiles. But here's the problem now.
> > In the frmts/ecw directory the compiler has problems. Mostly it seems to
> > do with typedefs. It looks like the gdal code needs to #include "ECW.h".
> > This help resolve alot of the problems, however there are still some I
> > haven't tracked down. Am I the only one having issues with this? Has
> > anyone else tried these libraries? I'm building on Suse 9.3 64-bit.
> > Thanks for any help.
> > > I've got the ECW SDK 3.2 (11 Jun 2005 ) built. I tried to configure gdal
> > > (cvs checked out 03 Aug 2005 ) with it, but the configure script is
> > > looking for the libNCSE*.so files and the ecw 3.2 builds one library named
> > > libecwj2.so. Is there a patch or trick to get it to work that I'm
> > > missing?
> > > _______________________________________________
> > > Gdal-dev mailing list
> > > Gdal-dev at lists.maptools.org
> > > http://lists.maptools.org/mailman/listinfo/gdal-dev
