[Gdal-dev] GDAL 1.3.0 Beta1 Released
Alessandro Amici lists at b-open-solutions.it
Mon Aug 8 05:14:41 EDT 2005
Frank,
to correct my initial posting i actually take a reference to a band with
GetBand(1) and not to the dataset it is attached to.
On Sunday 07 August 2005 23:56, Frank Warmerdam wrote:
> This does sound like something is corrupt in the GDALRasterBand
> (or GDALDataset).
any chance that the dataset reference count goes to zero if i only bring along
the band object...
[trying...]
BINGO!
if i carry along a reference to the original dataset together the reference to
that raster band everything works ;)
so, from the look of it the ReadAsArray method uses something from the dataset
c++ object, but the 'pythonic' band object doesn't take a 'pythonic'
reference to its parent dataset that gets garbage collected. is it right?
> Anything odd about your platform? (ie. 64bit or non-x86).
nope, just a dual-cpu: debian i386 k7-smp. nothing fancy.
i'm going to work around this problem, for now.
i'll try to send you a minimal sample of code that demonstrate the problem.
cheers,
alessandro
B-Open Solutions srl - http://www.bopen.it/
