[Gdal-dev] 1.3.0b1 missing file
Frank Warmerdam
fwarmerdam at gmail.com
Mon Aug 8 16:12:58 EDT 2005
On 8/8/05, James E. Hopper <JAMES.E.HOPPER at saic.com> wrote:
> the file :
> gdal_building.html
> is missin from the beta distribution. called from index_raw.html in
> folder doc.
James,
gdal_building.html is built from gdal_building.dox using Doxygen.
To use this you would need to have a reasonably recent Doxygen
installed on your system, and then do "make docs" in the main
directory.
The index_raw.html is used in generating the index.html but isn't
intended to be used directly.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
