[Gdal-dev] problems building gdal with xerces and ecw
Frank Warmerdam fwarmerdam at gmail.com
Mon Aug 22 11:11:21 EDT 2005
On 8/22/05, Raphaƫla Saling <raphaela_saling at caramail.com> wrote:
>  /usr/bin/ld: warning: libstdc++.so.5, needed by /usr/src/pourmapserver/ecwsdk-3.1.25Jan05-linux/lib/libNCSEcw.so, may conflict with libstdc++.so.6
Raphaƫla,
I can see a couple solutions to this.
 - GDAL 1.3.0's configure logic for Xerces now ignores warnings so it shouldn't
   be so sensitive to this problem.
 - Build the ECW SDK yourself from source, so that it will be linked with the
   same libstdc++ that you are using for everything else.   This can be tricky
   of course.
Best regards,
