[Gdal-dev] Installing header files?
Jonathan Greenberg
jgreenberg at arc.nasa.gov
Tue Aug 23 14:06:28 EDT 2005
Is there a trick to getting GDAL 1.3.0 to install all the header files in
the appropriate locations? I can probably hand-copy them, but I'm trying to
compile GRASS 6.1, for instance, and it needs the jpeglib.h include. I did
a file search and found it IN the gdal-1.3.0 source distribution but it does
not appear to get installed when I do a configure-> make-> make install.
--j
Jonathan A. Greenberg, PhD
NRC Research Associate
NASA Ames Research Center
MS 242-4
Moffett Field, CA 94035-1000
Office: 650-604-5896
Cell: 415-794-5043
AIM: jgrn307
MSN: jgrn307 at hotmail.com
