[Gdal-dev] Re: [GRASSLIST:8037] Order of ops for GRASS with GDAL support install?
Markus Neteler neteler at itc.it
Wed Aug 24 04:53:19 EDT 2005
On Tue, Aug 23, 2005 at 02:55:50PM -0700, Jonathan Greenberg wrote:
> BABA Yoshihiko has been doing a great job getting GDAL and GRASS working
> under the fink package manager, but I'm noticing a slightly odd way of
> getting GRASS with GDAL support -- am I correct in noticing there are
> cyclical dependencies, e.g. You have to first compile gdal, then compile
> grass with gdal support, then compile gdal with grass support?  If this is
> true, is there any way to get around this?
I am doping this procedure:
HOWTO compile GDAL/GRASS/GRASS-plugin:
  1. compile GDAL without GRASS support (see ./conf_gdal.sh [1] )
  2. compile GRASS itself (see ./conf_grass61_linux.sh [1] )
  3. configure/compile/install GDAL/GRASS plugin (see ./conf_install_gdal_grass_plugin.sh [1])
  4. link GRASS libs into /usr/local/lib/
  5. run 'ldconfig' (as root)
[1] http://mpa.itc.it/markus/useful/
Hope this helps
 Markus
