[Gdal-dev] GDAL+MrSID on Apache+MapServer in Chameleon application
Frank Warmerdam fwarmerdam at gmail.com
Wed Aug 24 16:33:17 EDT 2005
On 8/24/05, Peter Kingsbury <peter.kingsbury at gmail.com> wrote:
> Hello all,
> I am attempting to enable MrSID functionality in Chameleon, and have
> come to a roadblock. I am trying to compare performance between SID and
> TIF files, to see if it is a viable format for my application.
> The host is Windows XP SP2, GDAL 1.3.0 + MrSID on Apache 4 + MapServer
> (MS4W), using the Chameleon application.
Peter,
Does "gdalinfo --format mrsid" report some information indicating
the driver is available?  Does gdalinfo on the file in question
work?
What version of MS4W are you using?  I hadn't realized a new
one with GDAL 1.3.0 had been released.  If you are using an
MS4W with GDAL 1.2.6 or earlier, then you cannot just replace
the GDAL DLL with a new 1.3.0 one and have it work.
Best regards,
