[Gdal-dev] adding gcp's
Frank Warmerdam
fwarmerdam at gmail.com
Wed Aug 24 17:01:57 EDT 2005
On 8/23/05, Bart van den Eijnden <bartvde at xs4all.nl> wrote:
> Hi Frank,
> so will this generated file work with Mapserver (my experience is that it
> would not show up with Mapserver)?
Bart,
You are correct that MapServer does not currently support rasters
with only GCP georeferencing.
> Is the only way to work around it add a tfw or TAB file?
As Vincent suggested, you can use gdalwarp to rectify the image
and produce something that can be used in mapserver. You could
add a .tfw file since you clearly have an affine transformation for your
two control points.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
