[Gdal-dev] swig/perl
Ari Jolma
ari.jolma at tkk.fi
Wed Aug 31 18:13:56 EDT 2005
Ken Boss wrote:
>Hello Ari--
>I think Howard Butler and Kevin Ruland have already laid much of the groundwork that you'll require with their "next generation" (ng) GDAL bindings project. See Howard's recent post at http://lists.maptools.org/pipermail/gdal-dev/2005-August/006120.html.
>Further, Schuyler Erle did some preliminary work on perl bindings for GDAL a while back (http://search.cpan.org/~sderle/Geo-GDAL/). I think in particular you might find his typemap work (http://search.cpan.org/src/SDERLE/Geo-GDAL-0.11/typemap) to be of use.
Thanks. Well, after a few hours of learning swig, perlguts, etc, I could
finally get my first "hello world, this is your spatial data:..."
running. My typemaps_perl.i (which is basically where the porting
happens) is based on the python one but the internals had to be changed
of course. "make generate" gives two warnings because it can't apply
IF_FALSE_RETURN_NONE and "tostring argin" because I just removed those
typemaps for now. I have a small Makefile.PL (perl standard) which makes
a Makefile ok but "make -f Makefile" fails saying there are two
_wrap_GetDriverCount's, the other is of course from OGR. If I fix that
by hand (edit ogr_wrap.cpp by hand) it compiles. I don't know how to
control the naming of the _wrap function, %rename does not seem to do
that. I then have a small test.pl which does gdal::AllRegister, opens a
GTiff and prints out some info from it, works ok but method names are a
bit odd: e.g. "$dataset->swig_RasterXSize_get" works but not
"$dataset->RasterXSize".
Ari
