[Gdal-dev] CreateCopy into buffer
Thu Dec 1 11:58:49 EST 2005
On 12/1/05, Curt, WE7U <archer at eskimo.com> wrote:
> > ERROR 1: CPLVerifyConfiguration(): byte order set wrong.
> > Abort trap
> > Any Ideas on this problem ?
> It looks like it could be libgeotiff or libgdal/ogr that is bringing
> the CPL stuff in.  Are there any known problems with MacOSX and the
> CPL code?
Curt,
I haven't run into this before.  Basically it indicates
that the CPL_LSB / CPL_MSB macros were set wrong
in cpl_config.h by configure.  Is there any possibility
that a cpl_config.h got copied with the source from
a little endian system?
Looking at the code, I see that CPLVerifyConfiguration()
is called for every CPLMalloc() call.  Yikes!
Best regards,
