[Gdal-dev] colortable: unwanted increase of colors
Chris cb at delta-h.de
Fri Dec 2 10:39:30 EST 2005
Hello!
When I use gdal to copy an existing .tif file, which has two colors in
it's colortable, the copy gets 256 colors, which has the nasty
side-effect of larger files and slower performance (while displaying the
file in my app).
How can I save a copy with exactly the same colortable as my original file?
Attached you find the method I use, stripped to the minimum.
Thanks in advance!
Chris
---8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<-------8<----
void SaveAs(const std::string& origFile, const std::string& fname)
    GDALAllRegister();
    GDALDataset  *poDataset = (GDALDataset *) GDALOpen(
origFile.c_str(), GA_ReadOnly );
    GDALDataset* poDstDS =
        poDataset->GetDriver()->CreateCopy(
                fname.c_str(),
                poDataset,
                FALSE,
                NULL,
                GDALTermProgress,
                NULL);
    delete poDstDS;
