[Gdal-dev] Append two shapefiles
Alex Mandel
tech_dev at wildintellect.com
Mon Dec 5 14:26:56 EST 2005
Goal: Append two shapefiles together. One of the shapefiles has 2
additional fields(shp2).
Current attempt to get ogr2ogr to work on the commandline as an interem
solution fails. I can't seem to get the syntax right;
ogr2ogr -update -append -f "ESRI Shapefile"
"C:\Boxes\sandbox\one\shp1.shp" "C:\Boxes\sandbox\two\shp2.shp"
Fails to create file
Fails to open Shapefile
ogr2ogr -update -append "C:\Boxes\sandbox\three\rapix3.shp"
"C:\Boxes\sandbox\two\rapix2.shp" -nln "C:\Boxes\sandbox\three\rapix3"
"C:\Boxes\sandbox\two\rapix2"
Exits with no error, but doesn't do anything either.
Preferable solution is to hook into a python module in the FWtools or
GDAL but I haven't figured out how to import ogr.py yet it since import
gdal returns an error Numeric not found and I havne't quite fiqured out
how to import from the FWtools, I tried copying the pymod folder to my
sites-packages but I guess that doesn't work because there's no
__init__.py, maybe I should just make one?
Thanks,
Alex
PS: Everything must work on a windows machine, the only compilers I have
access to are Cygwin & MinGW not that I know how work them right.
