[Gdal-dev] Append two shapefiles
Dylan Beaudette
dylan.beaudette at gmail.com
Tue Dec 6 13:20:22 EST 2005
Hi Alex,
You might want to talk to Howard Butler about that- he seems to be doing a lot
of work on Python-GDAL stuff in windows.
Good luck,
Dylan
On Monday 05 December 2005 05:49 pm, Alex Mandel wrote:
> Thanks Dylan -
> I was putting full paths for the layers and using the -f, and for this
> time I also switched my slashes \ to / and it works great now.
> The next questions is how can I get just the ogr2ogr component into my
> program. I need to distribute a very thin and lite python program and
> can't expect my users to have FWtools.
> Ironically I think I'm one error away from writing a python module with
> gdal to do what I want, which would save me a ton of MB and give me
> control to copy only certain points.
> There's something wrong with the geometry line though. boa says that
> feat2.SetGeometry(pnt) has invalid syntax
> Anyone see my mistake right away, I figure it's something obvious that I
> just haven't learned yet. Keep in mind I'm only dealing with points, and
> will never need to handle any other geometry type.
> Thanks Everyone - Alex
> import gdal
> import gdal.ogr as ogr
> #Set ESRI Shapefile driver just in case
> driver = ogr.GetDriverByName('ESRI Shapefile')
> #Bring in 1st Shapefile, src
> ds1 = driver.Open("C:/Boxes/sandbox/one/one.shp")
> pLayer1 = ds1.GetLayer(0)
> #initialize first feature read
> feat = pLayer1.GetNextFeature()
> #Bring in 2nd Shapefile, dest
> ds2 = driver.Open("C:/Boxes/sandbox/two/two.shp")
> pLayer2 = ds2.GetLayer(0)
> #Count the numnber of fields
> layerDef2 = pLayer2.GetLayerDefn()
> field_count = layerDef.GetFieldCount()
> #Create index of fields to copy
> fld_list = {}
> for i in range(layerDef2.GetFieldCount()):
> field = layerDef.GetFieldDefn(i)
> fld_list[field.GetName()] = i
> while feat is not None:
> multi_geom = feat.GetGeometryRef()
> for i in range(multi_geom.GetGeometryCount()):
> pnt = multi_geom.GetGeometryRef(i)
> feat2 = ogr.Feature(feature_def=layerDef2)
> #Copy Feature table data
> for fld_index in range(field_count):
> fld_name = layerDef.GetFieldDefn(fld_index)
> #if fld_list.has_key(fld_name.GetName()):
> feat2.SetField(fld_index, \
> feat.GetField(fld_list.get(fld_name))
> #Paste into destination
> pLayer2.CreateFeature(feat2)
> feat2.Destroy()
> #Clean up and iterate
> feat.Destroy()
> Dylan Beaudette wrote:
> > hi Alex!
> > didn't know you were lurking here!
> > welcome the GDAL land --
> > lots of good stuff here.
> > here is how i do it:
> > ogr2ogr -update -append $merge_file $this_file_to_append -nln
> $merge_layer
> > $this_file_to_append_layer
> > where the 2nd set of 'layers' are missing the '.shp' suffix.
> > cheers,
> > Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
