[Gdal-dev] Problem with gdal+postgresql on RHEL3
Martin Spott Martin.Spott at mgras.net
Mon Dec 12 14:20:02 EST 2005
"Thom DeCarlo" wrote:
> However, when I try to compile gdal the linker picks up the wrong version of
> PostgreSQL. (The computer came with an older version of PostgreSQL installed
> and I'm not sure what will break if I just delete it.)
Simply try do "rpm -e" the old PostgreSQL installation. If other
packages depend on it, RPM will tell you. Having incompatible versions
of a library is almost always a bad idea (TM  ;-)
Cheers,
	Martin.
 Unix _IS_ user friendly - it's just selective about who its friends are !
