[Gdal-dev] ERDAS IMG .aux file
Reinaldo Escada Chohfi rec at geodesign.com.br
Wed Dec 14 12:54:22 EST 2005
Hello Frank,
Thanks for the info.  So far I've been using the fwtools.  Now, I tried
building gdal for the first time but I got the following error message at
the end of the process
C:\Arquivos de programas\Microsoft Visual Studio\VC98\lib\MSVCRT.lib :
fatal error LNK1106: invalid file or disk full: cannot seek to
0x35894cc8NMAKE : fatal error U1077: 'link' : return code '0xc'
Stop.
The HD am building on has 42 GB of free space.  Any suggestions on what's
going on?
Thanks in advance.
Reinaldo
At 08:20 PM 12/13/2005, Frank Warmerdam wrote:
>On 12/13/05, Reinaldo Escada Chohfi <rec at geodesign.com.br> wrote:
> > Hi,
> > Does anyone know where one could get information on the ERDAS .aux file
> format?
>Reinaldo,
>Erdas .aux files are in Hierarchical File Architecture format,
>the same as .img files.  You can read the specification
>documents from Erdas (err, Leica).
>   http://home.gdal.org/projects/imagine/iau_docu1.pdf
>You can also dump .aux files with the "hfatest" utility
>that can be built in gdal/frmts/hfa.   You would use it like:
>hfatest -dt  ungeo_bmp.aux
>   DependentFile(Eimg_DependentFile) @ 210 + 22 @ 338
>   + dependent =
>   +     string = `ungeo_bmp.bmp'
>   Band_1(Eimg_Layer) @ 360 + 20 @ 488
>   + width = 1119
>   + height = 1122
>   + layerType = athematic
>   + pixelType = u8
>   + blockWidth = 1119
>   + blockHeight = 1
>     Projection(Eprj_ProParameters) @ 2013 + 223 @ 2141
>     + proType = EPRJ_INTERNAL
>     + proNumber = 2
>     + proExeName = (no values)
>Best regards,
>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush    | Geospatial Programmer for Rent
Reinaldo Escada Chohfi, Ph.D.
Diretor
GeoDesign Internacional
www.geodesign.com.br
E-mail: rec at geodesign.com.br
Tel./Fax: 0-XX-12-3153-5115 (Local)
       55-12-3153-5115 (Intl.)
Inteligência e Tecnologia Espacial de Ponta
Urbanismo, Estudos Ambientais, Monitoriamento Ambiental,
Geoprocessamento, GIS, Processamento de Imagens Geográficas,
Sensoriamento Remoto: Imagens de Satélites
Compressão de Imagens e Documentos Escanerizados
Servidor de Conteúdo - Integração de Sistemas
Revendedor Autorizado da LizardTech no Brasil
Vila Peralta, 42
12607-040 - Lorena - SP - Brasil
Informação confidencial. Não retransmitir sem autorização.
Copyright (c) 2005 GeoDesign Internacional
Todos os direitos reservados.
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20051214/b808ada0/attachment.html
