[Gdal-dev] Loop through Microstation and project
Rob McCulley
RMcCulley at county24.com
Wed Dec 14 13:42:14 EST 2005
Hello All,
I'm fairly new to GDAL/OGR, and Python, so forgive my ignorance.
I'm trying to loop through a bunch of microstation files, and copy the features into a single shapefile. Everything works fine at first, but at the end of the first microstation file I get the following error:
File "S:\Rob\Python_Scripts\ProcessAltalis.py", line 26, in ?
oldGeom = feature.GetGeometryRef()
AttributeError: 'NoneType' object has no attribute 'GetGeometryRef'
I assume it is a result of how I iterate through the microstation features. Here is my code:
import os
import glob
from gdal import ogr
list = glob.glob('C:/GIS/Altalis/20051121/Cadastral/*.dgn')
driver = ogr.GetDriverByName('ESRI Shapefile')
cadastral_shp = driver.CreateDataSource('C:/GIS/Altalis/20051121/Cadastral/Cadastral.shp')
cadastral = cadastral_shp.CreateLayer('Cadastral',geom_type=ogr.wkbLineString)
field = ogr.FieldDefn('Level',ogr.OFTInteger)
field.SetWidth(8)
cadastral.CreateField(field)
field = ogr.FieldDefn('File',ogr.OFTString)
field.SetPrecision(8)
for file in list:
microstation = ogr.Open(file)
layer = microstation.GetLayer(0)
layer.ResetReading()
i = 0
j = layer.GetFeatureCount()
while i < j:
feature = layer.GetNextFeature()
geomType = oldGeom.GetGeometryType()
if geomType == ogr.wkbLineString:
newFeature = ogr.Feature(cadastral.GetLayerDefn())
gml = oldGeom.ExportToGML()
newGeom = ogr.CreateGeometryFromGML(gml)
newFeature.SetGeometryDirectly(newGeom)
level = feature.GetFieldAsInteger(1)
newFeature.SetField(0, level)
newFeature.SetField(1, os.path.basename(file))
cadastral.CreateFeature(newFeature)
feature.Destroy()
microstation.Destroy()
cadastral_shp.Destroy()
The second question I have is, how do I go about converting the features from one projection to another during this process. I know what my projections are. The source data is in a 10TM projection (proj: +proj=tmerc +lon_0=-115 +k_0=0.9992 +x_0=500000 +datum=NAD27) and the target projection is EPSG:2152 (NAD83 CSRS98 12N). I looked through the Projection Tutorial, but I can't figure out how to do that using python.
Thank You,
Rob McCulley
GIS Coordinator
County of Vermilion River No. 24
(780) 846-2244
rmcculley at county24.com
