[Gdal-dev] Determine Geometry Field name?
Craig Miller craig.miller at spatialminds.com
Thu Dec 15 22:46:39 EST 2005
I've been looking throught C++ API, trying to determine if there is some way
to determine what the name is of the field in the feature that contains the
geometry.  I need it to pass a custom query via ExecuteSQL.  I only need to
do this for the PG driver so I could query the geometry_columns table
directly, but it would be better if I could get it via the API.
Thanks for the help,
Craig
