[Gdal-dev] read prj & metadata from .html file?
Matt Wilkie matt.wilkie at gov.yk.ca
Wed Feb 2 11:39:16 EST 2005
Hi Ed,
> From the GDAL output you sent me separately,
Oops, that was supposed to be general to the list. Is there a particular
reason the default ReplyTo is the individual not the list?
> Updating your EPSG projection definitions to include the values
> reported by the GeoTIFFs you're using is probably the quickest,
> simplest, and most reliable route to a solution.
Oh, I would definately prefer that to my hack-attack. :) I'm glad I
decided to post the gdalinfo output. I almost just let it slide.
How do I update the EPSG projection defintions? I'm using FWTools 0.9.5
on WindowsXP.
thanks,
matt wilkie
Geographic Information,
Information Management and Technology,
Yukon Department of Environment
10 Burns Road * Whitehorse, Yukon * Y1A 4Y9
867-667-8133 Tel * 867-393-7003 Fax
