[Gdal-dev] ogr.py enhancement proposal
Homme Zwaagstra hrz at geodata.soton.ac.uk
Thu Feb 3 04:37:43 EST 2005
Hello,
As a fellow enthusiast for ogr/gdal on the command line, I think the
proposals for making the library more pythonic are a great idea! I
find exploring and manipulating a dataset interactively very useful
and the proposals would save a lot of typing :)
In the same vein, would anyone else find an implementation of the
__str__() method on some objects useful? The Feature and Geometry
objects spring to mind...
class Geometry:
	  def __str__(self):
		  return self.ExportToWkt()
class Feature:
	  def __str__(self):
		  return self.DumpReadable()
This way using the print statement on such an object would be slightly
more revealing than at present.
Kind regards,
Homme Zwaagstra
On Wed, Feb 02, 2005 at 10:11:26AM -0600, Howard Butler wrote:
> Folks,
> I have been making some enhancements to ogr.py to make it more pythonic and
> more convenient to program with, especially in the interactive mode which
> Python excels so well with.  Below is a short list of the enhancements I've
> already made, and a proposal for further enhancements that I would like to
> implement.  These changes are completely backward compatible (all the way
> back to 2.0), and you do not have to use them to program with ogr.py.  I'm
> interested in you feedback as to whether or not this work would be
> beneficial, keeping in line with the direction and history of ogr.py, and
> if you think they are a good idea.
> The major enhancement that I made was to allow slicing and index access to
> Layer and DataSource.  Here is an example of what I mean:
> # Get the first layer on the DataSource
> ds = ogr.Open(my_data_location)
> # current approach
> lyr = ds.GetLayer(0)
> # enhanced approach
> lyr = ds[0]
> The advantage of this approach is that we get slicing and looping for free
> from Python.  For example:
> # Put the first four layers into a list
> layers = ds[0:4]
> # Put all the layers in a list except the first one
> layers = ds[1:]
> # Print the names of all of the layers on the DataSource
> for i in ds:
>     print i.GetName()
> The same enhancement was made to the Layer object as well.  It is important
> to note, however, that you are not *guaranteed* sequential access to the
> Features in a layer.  This approach will work for the majority of cases,
> but if you have a funky DataSource/Layer, you might not always get what you
> expect.
> # Get the first 10 features of the first layer
> # current approach
> features = []
> for i in range(lyr.GetFeatureCount()):
>     if i < 11:
>         features.append(lyr.GetFeature(i))
> # enhanced approach
> lyr = ds[0]
> features = lyr[0:10]
> # again, we get looping and slicing for free
> for i in lyr[0:10]:
>     print i.GetField(0)
> Feature Enhancement Proposal
> I would like to extend Feature to support run-time attribute
> lookup.  Thanks to Frank's enhancement to allow features to clean up after
> themselves, it would now be straightforward to allow you to access field
> information as a direct attribute of the feature, rather than being forced
> to look up the field's index and then request the information.  For example:
> # Add two attribute columns together
> # Table layout
> #------Column1-------------Column2------------
> #           3                       4
> #           6                       9
> #           10                     22
> # current approach
> features = []
> values = []
> for feat in features:
>     val1 = feat.GetField(feat.GetFieldIndex('Column1'))
>     val2 = feat.GetField(feat.GetFieldIndex('Column2'))
>     values.append(val1+val2)
> # enhanced approach
> lyr = ds[0]
> features = lyr[:]
> values =[]
>     values.append(feat.Column1+feat.Column2)
> There are definitely some gotchas with this approach.  First, if the column
> name has funky characters in it, the convenience isn't that great (you
> might have to escape special python characters like quote and double quote,
> for example).  Second, does accessing things this way muddy up what a
> "Feature" is and how things are accessed?  When I request a Field, like
> feat.Column2, am I getting back the *value* of the Feature in that Field,
> or the definition of the Column2 field?
> On the other hand, the convenience is quite great.  For example, in the
> interactive prompt, you would be able to go dir(feat) and see all of the
> attribute columns of the layer.  In my opinion, your code could be a bit
> more concise and clear, and things like printf-style string substitution
> would be much easier to read.
> Again, I'm looking for your (and Frank's!) opinion on the proposed
> enhancement.  You would not be required to use these enhancements in your
> old or new code, but they would be there for you if you need them.  Would
> something like this make your life with ogr.py easier?  Does something like
> this break from the unified (C/C++/Python) API in too great a way?
> Howard
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
Homme Zwaagstra
GeoData Institute
University of Southampton
