[Gdal-dev] help with OGR->python
Dylan Beaudette
dylan at iici.no-ip.org
Fri Feb 4 20:37:59 EST 2005
thanks to everyone who replied...
I think that Frank's comments are right on -- if there was some simple way to
extract features -- points,lines,polygons, into a list of X,Y pairs it would
be great.
Perhaps it would be a good idea to state my goal:
I have quite a bit of vector data in shapefile format. However, i would like
to make my maps with GMT -- which expects vector data in the following
format: (note that ">" is a flag meaning "start new feature")
>Y,X #start of feature 1
Y,X
Y,X
Y,X
>Y,X #start of feature 2
Y,X
Y,X
Y,X
I need to be able to traverse the geometry of polygons in a shapefile and
output these coordinate lists with a ">" at the start of each feature.
Any ideas would be quite helpful. Or, if anyone has figured out the
shapefile->GMT problem in the past...
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
On Friday 04 February 2005 01:22 pm, Frank Warmerdam wrote:
> On Fri, 04 Feb 2005 16:14:56 +0100, Julien Demaria <dem at acri-st.fr> wrote:
> > Dylan,
> > The trick is that in the OGR C and Python APIs, a Geometry can contains
> > others Geometries (accessible with Geometry::GetGeometryCount() and
> > Geometry::GetGeometryRef( i )), and that a Polygon has not directly
> > points,
> Folks,
> Juliens analysis is quite right. But clearly it would be handy
> to have more direct ways of extracting the lists of points from a
> geometry without having to do so much iteration. Perhaps we
> need a method that returns the points of a geometry as a list
> of point tuples. This method could know about "walking" the
> children of a geometry and build up a sort of list of lists to
> match up with the geometries.
> So a polygon would have a list of rings, each ring would be a
> list of points in that ring. Each point would be an (x,y,z) tuple.
> Howard, would you be interested in implementing such a method
> on the Geometry? Though when I think about it, it might be more
> efficient to implement it in C.
> Best regards,
