[Gdal-dev] EPSG file path
Frank Warmerdam fwarmerdam at gmail.com
Fri Feb 11 12:49:14 EST 2005
Adam,
You can override where this code looks for the EPSG calls by setting the
GEOTIFF_CSV environment variable, or by setting it as a configuration
option from code.
eg.
  CPLSetConfigOption( "GEOTIFF_CSV", "/my/epsg/csv/directory" );
On Fri, 11 Feb 2005 09:31:09 -0800, Adam Guernsey <adam at ctech.com> wrote:
> Hello there,
> I am looking at implementing the OGRSpatialReference
> ::importFromEPSG (  int  nCode  )  function.  I have had no problems getting
> it to work, however I was wondering if it was possible to change the path to
> the csv files that it uses for the lookup.  I am using the release right
> now, and would like to do this without altering the source.
> Thanks
> Adam Guernsey
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
