[Gdal-dev] 2004 Tiger with new PostGIS
David Blasby
dblasby at gmail.com
Mon Feb 14 13:45:39 EST 2005
I'm trying to load the new Tiger data into Postgis, and I'm having troubles.
I solved the "constraints" on tables problem - just run the CREATE
FUNCTION statement below - it replaces the addgeometrycolumn function
so that it doesnt add constaints. Hacky, but it works.
The second problem is with OGR - the altNames table isn't correctly
forming arrays:
LOG: statement: INSERT INTO "altname" ("module", "tlid", "rtsq",
"feat") VALUES ('TGR11001', 76224848, 1, '{696,702')
the '{696,702' should have a "}" at the end - '{696,702}'. I dont
want to just ignore errors since I'll lose everything inside the
transaction.
Is it possible to get ogr to spit out sql instead of actually hitting
the database? That way I can write a perl script to fix the problems.
Anyone else trying to load the 2004 data?
CREATE OR REPLACE FUNCTION
AddGeometryColumn(varchar,varchar,varchar,varchar,integer,varchar,integer)
RETURNS text
AS
DECLARE
catalog_name alias for $1;
schema_name alias for $2;
table_name alias for $3;
column_name alias for $4;
new_srid alias for $5;
new_type alias for $6;
new_dim alias for $7;
rec RECORD;
schema_ok bool;
real_schema name;
fixgeomres text;
BEGIN
IF ( not ( (new_type =''GEOMETRY'') or
(new_type =''GEOMETRYCOLLECTION'') or
(new_type =''POINT'') or
(new_type =''MULTIPOINT'') or
(new_type =''POLYGON'') or
(new_type =''MULTIPOLYGON'') or
(new_type =''LINESTRING'') or
(new_type =''MULTILINESTRING'') or
(new_type =''GEOMETRYCOLLECTIONM'') or
(new_type =''POINTM'') or
(new_type =''MULTIPOINTM'') or
(new_type =''POLYGONM'') or
(new_type =''MULTIPOLYGONM'') or
(new_type =''LINESTRINGM'') or
(new_type =''MULTILINESTRINGM'')) )
THEN
RAISE EXCEPTION ''Invalid type name - valid ones are:
GEOMETRY, GEOMETRYCOLLECTION, POINT,
MULTIPOINT, POLYGON, MULTIPOLYGON,
LINESTRING, MULTILINESTRING,
GEOMETRYCOLLECTIONM, POINTM,
MULTIPOINTM, POLYGONM, MULTIPOLYGONM,
LINESTRINGM, or MULTILINESTRINGM '';
return ''fail'';
END IF;
IF ( (new_dim >4) or (new_dim <0) ) THEN
RAISE EXCEPTION ''invalid dimension'';
return ''fail'';
END IF;
IF ( (new_type LIKE ''%M'') and (new_dim!=3) ) THEN
RAISE EXCEPTION ''TypeM needs 3 dimensions'';
return ''fail'';
END IF;
IF ( schema_name != '''' ) THEN
schema_ok = ''f'';
FOR rec IN SELECT nspname FROM pg_namespace WHERE text(nspname) =
schema_name LOOP
schema_ok := ''t'';
END LOOP;
if ( schema_ok <> ''t'' ) THEN
RAISE NOTICE ''Invalid schema name - using current_schema()'';
SELECT current_schema() into real_schema;
ELSE
real_schema = schema_name;
END IF;
ELSE
END IF;
-- Add geometry column
EXECUTE ''ALTER TABLE '' ||
quote_ident(real_schema) || ''.'' || quote_ident(table_name)
|| '' ADD COLUMN '' || quote_ident(column_name) ||
'' geometry '';
-- Delete stale record in geometry_column (if any)
EXECUTE ''DELETE FROM geometry_columns WHERE
f_table_catalog = '' || quote_literal('''') ||
'' AND f_table_schema = '' ||
quote_literal(real_schema) ||
'' AND f_table_name = '' || quote_literal(table_name) ||
'' AND f_geometry_column = '' || quote_literal(column_name);
-- Add record in geometry_column
EXECUTE ''INSERT INTO geometry_columns VALUES ('' ||
quote_literal('''') || '','' ||
quote_literal(real_schema) || '','' ||
quote_literal(table_name) || '','' ||
quote_literal(column_name) || '','' ||
new_dim || '','' || new_srid || '','' ||
quote_literal(new_type) || '')'';
-- Add table checks
SELECT fix_geometry_columns() INTO fixgeomres;
return
real_schema || ''.'' ||
table_name || ''.'' || column_name ||
'' SRID:'' || new_srid ||
'' TYPE:'' || new_type ||
'' DIMS:'' || new_dim || ''\n '' ||
''geometry_column '' || fixgeomres;
END;
LANGUAGE 'plpgsql' VOLATILE STRICT; -- WITH (isstrict);
