[Gdal-dev] citing GDAL/OGR
Frank Warmerdam
fwarmerdam at gmail.com
Mon Feb 14 18:17:19 EST 2005
On Mon, 14 Feb 2005 14:46:53 -0800, Carlos A. Rueda <carueda at ucdavis.edu> wrote:
> We are planning a paper describing a tool which uses the GDAL/OGR library
> and we would like to make a proper citation. Is there any preferred
> citation we should use? --thanks.
Carlos,
I have no preference other than that I would like you to use
http://www.gdal.org/ as the permanent location at which to find
information on GDAL/OGR.
Thanks,
and watch the world go round - Rush | Geospatial Programmer for Rent
