[Gdal-dev] OGR Polygon question
Frank Warmerdam
fwarmerdam at gmail.com
Wed Feb 16 16:56:44 EST 2005
On Wed, 16 Feb 2005 16:12:09 -0500, William Lyons
<wlyons at prologic-inc.com> wrote:
> Howdy List,
> Just a quick question about the capabilities of the OGR C API.
> Is it possible to differentiate between the exterior and interior rings of
> an OGRPolygon via the C API?
William,
Properly speaking the OGRPolygon is only supposed to have one
exterior ring, and it should be the outside. There are likely some OGR
drivers that still return multipolygons as polygons in which case there is
no real way to determine what are exterior rings. But the correct solution
is for the underlying driver to be fixed.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
