[Gdal-dev] MrSID, GDAL & Mapserver
Frank Warmerdam
fwarmerdam at gmail.com
Fri Feb 18 00:16:26 EST 2005
On Thu, 17 Feb 2005 19:46:07 -0700, Chapman, Martin <MChapman at sanz.com> wrote:
> Yar,
> I really couldn't tell you whether it's all correct or not, but it looks like gdal read it just fine...which would mean your problem is somewhere else. I did notice it's pretty big though. It may take several minutes to open if MapServer is loading the whole thing. Did you copy the new gdal lib and dll into the mapserver directory for libs? Can you open it with the imageviewer exe that comes with the mrsid sdk? It's in /bin or something like that. Can you try to use a smaller sid file. This sounds like a MapServer config issue to me.
> Martin
Yar,
I agree with Martin. I don't see anything odd about the
file, so you should review your mapfile definitions
(especially extents and coordinate system) carefully,
and of course ensure that your MapServer is really
using the same GDAL as the gdalinfo you ran.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
