[Gdal-dev] GDAL GCPsToGeoTransform Problem
Eric Dönges eric.doenges at gmx.net
Fri Feb 18 02:07:33 EST 2005
Am 17.02.2005 um 16:52 schrieb Gillian Walter:
> Eric Dönges wrote:
>> While I am reasonably sure the GCPsToGeoTransform code is
>> mathematically correct (the
>> equations were determined with a symbolic algebra package), it is
>> probably not optimal
>> from a numerical standpoint. The problem is that if you have lots of
>> GCPs with large
>> coordinates, the calculations may overflow 'mere' 64 bit double
>> arithmetic (not being
>> a mathematician, I wrote the code for clarity, not numerical
>> stability). Looking
>> at the equations, I do not see an obvious solution for avoiding the
>> rather large
>> temporary values during the calculation.
> If large intermediate values are the problem, maybe the gcps could be
> shifted by an offset, and then shifted back?  ie. subtract mean(pixel
> values), mean(line values), mean(x values), mean(y values) from each
> gcp, do a fit to the shifted gcps so you'd end up with (where gt is
> the geotransform):
> x - xmean = gt[0] + gt[1](p - pmean) + gt[2](l - lmean)
> y - ymean = gt[3] + gt[4](p - pmean) + gt[5](l - lmean)
> then the real gt[0] and gt[3] would be:
> gt[0] actual = gt[0] + xmean - gt[1]*pmean - gt[2]*lmean
> gt[3] actual = gt[3] + ymean - gt[4]*pmean - gt[5]*lmean
> or something like that.   The fit code seems to have a lot of sums of
> squares of pixel/line/x/y values, and this should make them smaller.
> You might also be able to do some kind of normalization by spread to
> make them even smaller if necessary.
> Gillian
I'm not sure if this will help with floating point arithmetic, since
the way I
understand floating point arithmetic (and I may be completely wrong
here !), the
problem is not absolute magnitude (IEEE doubles go to something like
10^108 or so,
I believe), but relative magnitude between numbers. In our case, we
would need to
loose the products of pixel/line/x/y values, i.e. try to rework the
equations so that
the intermediate results are not several orders of magnitude larger or
smaller than
the input values. A possibly simpler solution might be to simply switch
to using
'long double'; however I am not sure how well this data type is
supported on
different compilers.
Another thought I had is that the original poster
(<dlegault at vantpoint.com>) should
check the return value of GCPsToGeoTransform - it may be that the
complete set
of GCPs does not result in a valid transform (which is possible if some
of the GCPs
are poorly placed) and thus the function returns gibberish.
With kind regards,
Eric
