[Gdal-dev] define block size for GTIFF
Xiaodong Zhang
zhang at aero.und.edu
Thu Feb 24 23:08:09 EST 2005
We're using GDAL to read in a binary raw image (already in projected format)line
by line and wrtie out as a GTIFF image after SetGeoTransform and SetProjectioin
using:
for (j=0,j<Yvalue;j++){
fread(rowData,sizeof(float),Xvalue,inFile);
poBand->RasterIO(GF_Write,0,j,Xvalue,1,rowData,Xvalue,1,GDT_Float32,0,0);}
I'm wondering how can I set a block size and how to use it. Will that be faster
than what I'm doing now.
Also I know GTIFF has an option of compressing image, does GDAL support that?
Thanks
Xiaodong
Quoting "Chapman, Martin" <MChapman at sanz.com>:
> Wow, that's power scripting. Very nice!
> Martin
> -----Original Message-----
> From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]
> Sent: Thu 2/24/2005 10:59 AM
> To: gdal-dev at remotesensing.org
> Cc:
> Subject: [Gdal-dev] Fwd: Thanks for GDAL
> Folks,
> I received this today, and thought there might be other
> interested in using GDAL with Blender.
> ---------- Forwarded message ----------
> From: Chris Soriano <chris.soriano at gmail.com>
> Date: Thu, 24 Feb 2005 09:49:42 -0800
> Subject: Thanks for GDAL
> To: warmerdam at pobox.com
> Hi Frank,
> Thanks for your work on GDAL. I use a 3D open source package called
> "Blender" (www.blender.org) that uses Python for scripting. By using a
> few lines in Python and the GDAL module, I was able to pull in some
> DEM data with no problem.
> Here is a discussion of my script with some screenshots:
> http://www.elysiun.com/forum/viewtopic.php?t=38108
> Thanks again,
> Chris Soriano
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
