[Gdal-dev] A typo in hfadataset.cpp
Frank Warmerdam
fwarmerdam at gmail.com
Thu Feb 24 23:45:37 EST 2005
On Thu, 27 Jan 2005 15:47:31 -0800, Yang, Zhiqiang
<zhiqiang.yang at oregonstate.edu> wrote:
> Hi,
> It seems like that there are two typos in hfadataset.cpp. The word
> "Azimuthal" was typed as "Azitmuthal" on line 1241 and 1250. As a result, if
> you set a projection to to "Lambert Azimuthal Equal-area" or "Azimuthal
> Equidistant", the resulting image will not be valid in projection.
Yang,
Thanks for reporting this (and via bugzilla) and it is now fixed.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
