[Gdal-dev] ENVIDataset::FlushCache is not idempotent for header
file
Frank Warmerdam
fwarmerdam at gmail.com
Mon Feb 28 10:40:37 EST 2005
On Sat, 26 Feb 2005 21:04:18 -0800, Carlos A. Rueda <carueda at ucdavis.edu> wrote:
> Hello Frank,
> I have just noticed that multiple calls to FlushCache on an ENVI dataset
> object will generate a header with repeated header items.
Carlos,
Hmm, I think I see what you mean. Can you submit a bug
report with details. It seems that we will need to alter the
header writing logic to keep the whole header in RAM so that
it can be completely re-written in FlushCache(), not just
appended to.
Also, a recent change by Gillian, makes this a less
frequent problem since it is now only written when dirty.
But I think if you altered the projection, flushed, altered
the projection again and flushed you would end up with
duplicate items.
> I also notice
> that the first call inside this method is to GDALDataset::FlushCache()
> but perhaps it should be to RawDataset::FlushCache().
True. I have changed it.
However, this does not currently make any difference as
there is no RawDataset::FlushCache() so it is just forwarded
to GDALDataset::FlushCache() anyways. Just cleaner,
future-safe coding to call the immediate parent classes method.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
