[Gdal-dev] Re: (GRASSLIST:5937) Re: loading VMAP0 data with v.in.ogr?
Frank Warmerdam fwarmerdam at gmail.com
Mon Feb 28 19:47:54 EST 2005
On Tue, 1 Mar 2005 12:59:58 +1300, Hamish <hamish_nospam at yahoo.com> wrote:
> Running it through the debugger shows this is as a SIGILL:
> $ gdb `which ogrinfo`
> GNU gdb 6.3-debian
> This GDB was configured as "i386-linux"...Using host libthread_db library "/lib/libthread_db.so.1".
> (gdb) run gltp:/vrf/var/local/topodata/vmap0/v0sas/vmaplv0/sasaus 'watrcrsl at hydro(*)_line'
> Starting program: /usr/local/bin/ogrinfo gltp:/vrf/var/local/topodata/vmap0/v0sas/vmaplv0/sasaus 'watrcrsl at hydro(*)_line'
> [Thread debugging using libthread_db enabled]
> [New Thread 16384 (LWP 25147)]
Hamish,
There have been a number of bug fixes since 3.1.4 but no new
formal release.  I'll prepare a 3.1.5 tonight and then hopefully you
can try with that tomorrow.
Sorry for not following up on your messages sooner.  I thought
Markus had hit it on the head with the lower case suggestion.
Best regards,
