[Gdal-dev] Shapefile spatial indexing
bartvde at xs4all.nl
Tue Jan 4 10:21:13 EST 2005
Hi Frank,
great! Can the spatial indexes also be created using shptree or must one
use the SQL CREATE SPATIAL INDEX syntax?
Best regards,
Bart
> Folks,
> I think I mentioned in the past that I was looking at implementing spatial
> indexing support for the OGR Shapefile driver. Martin Chapman (and SANZ)
> have encouraged me to complete that work and it is now all in CVS.
> It is implemented using the same quadtree style format (.qix) used by
> UMN MapServer. Indexes can be created and dropped with pseudo-SQL
> commands
> as noted in the updated shapefile driver document at:
> http://gdal.maptools.org/ogr/drv_shapefile.html
> With the spatial index build for a 400MB 900000 feature line file (roads
> in Virginia) I was able to read back a 77000 feature subset in 5s as
> opposed
> to 64s without the spatial index. I was able to read back a 1300 feature
> subset in 0.4s compared to 60s. So the spatial index does give massive
> improvements for reading small spatial regions out of large datasets.
> If anyone tries out the new capability and runs into problems, please let
> me
> know.
> Thanks to SANZ for funding this work, and Steve Lime for his
> implementation
> in MapServer!
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at xserve.flids.com
> http://xserve.flids.com/mailman/listinfo/gdal-dev
