[Gdal-dev] Memory leak related with reference counting
Marek Brudka
mbrudka at aster.pl
Fri Jan 7 15:08:12 EST 2005
GDAL VERSION: 1.25
AREA/CLASS/EXAMPLE AFFECTED:
OGR
DOES THE PROBLEM AFFECT:
COMPILATION?
LINKING?
EXECUTION? yes
OTHER (please specify)?
SYNOPSIS:
It seems OGR uses reference counting inconsistently, what result in
memory leak.
DESCRIPTION:
OGR uses reference counting for some object to manage the life cycle of
objects as well as to decrease OGR memory requirements.
In particular SpatialReferenceSystems are reference counted. While
reference counting is consistent in OGRProj4CT, namely
OGRSpatialReference are deleted when counter falls below 1, in
OGRGeometry eg. OGRGeometry::~OGRGeometry and
OGRGeometry::assignSpatialReference a counter is released without
checking if OGRSpatialReference should be deleted. This may
result in memory leak.
REPEAT BY:
Analyze places, where Reference/Dereference method is called.
SAMPLE FIX/WORKAROUND:
The quick fix is to check if reference counter falls below 1 and
eventually delete the object eg.
OGRGeometry::~OGRGeometry()
if( poSRS != NULL )
if ( poSRS->Dereference() <= 0 )
delete poSRS;
However, a better way to manage reference counted objects is to use
consistently in GDAL intrusive smart pointers.
If the dependency on boost libraries is accepted, then I propose to use
boost::instrusive_ptr
(http://www.boost.org/libs/smart_ptr/intrusive_ptr.html). If this
dependency is for some reason undesirable, then a
simple template (boost::instrusive_ptr is 273 lines long) for such
pointers can be written. I strongly recommend such
technique, as this is simple way to avoid related with reference counted
memory management.
Regards
Marek Brudka
