[Gdal-dev] Trapping coordinate transformation errors gracefully
Tim Sutton
tim at linfiniti.com
Mon Jan 10 06:25:58 EST 2005
Hi
I am trying to compute a transform for a rectangle. Sometimes invalid data is
being passed and I would like to be able to handle errors gracefully.
Currently when ogr throws this error message (I include a bit of qgis stdout
too for context):
vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv
Rect inverse projection...
INPUT:
PROJCS["Alaska_Albers_Equal_Area_Conic",GEOGCS["GCS_WGS_1984",DATUM["WGS_1984",SPHEROID["WGS_1984",6378137.0,298.257223563]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Albers_Conic_Equal_Area"],PARAMETER["False_Easting",0.0],PARAMETER["False_Northing",0.0],PARAMETER["longitude_of_center",-154.0],PARAMETER["Standard_Parallel_1",55.0],PARAMETER["Standard_Parallel_2",65.0],PARAMETER["latitude_of_center",50.0],UNIT["Meter",1.0]]
OUTPUT:
GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84
[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.0174532925199433,AUTHORITY["EPSG","9108"]],AXIS["Lat",NORTH],AXIS["Long",EAST],AUTHORITY["EPSG","4326"]]
INPUT RECT:
-173846,730736:255493,971426
ERROR 1: latitude or longitude exceeded limits
As you see from the code excerpt below I do try to trap for the transform
failing, but when the error is encountered QGIS segfaults. A backtrace is
included at the end of this email - though I dont have gdal built with
debugging support so I dont know how useful it is.
Many thanks for any help you may have to offer
Regards
Tim Sutton
inline QgsRect QgsCoordinateTransform::inverseTransform(QgsRect theRect)
if (mShortCircuit || !mInitialisedFlag) return theRect;
// transform x
double x1 = theRect.xMin();
double y1 = theRect.yMin();
double x2 = theRect.xMax();
double y2 = theRect.yMax();
#ifdef QGISDEBUG
std::cout <<
"vvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvvv"<<
std::endl;
std::cout << "Rect inverse projection..." << std::endl;
std::cout << "INPUT: " << std::endl << mSourceWKT << std::endl;
std::cout << "OUTPUT: " << std::endl << mDestWKT << std::endl;
std::cout << "INPUT RECT: " << std::endl << x1 << "," << y1 << ":" << x2 <<
"," << y2 << std::endl;
std::cout <<
std::endl;
#endif
// Number of points to reproject------+
// V
if ( ! mDestToSourceXForm->Transform( 1, &x1, &y1 ) || !
mDestToSourceXForm->Transform( 1, &x2, &y2 ) )
//something bad happened....
throw QgsCsException(QString("Coordinate inverse transform failed"));
else
#ifdef QGISDEBUG
std::cout << "Xmin : "
<< theRect.xMin()
<< "-->" << x1
<< ", Ymin: "
<< theRect.yMin()
<< " -->" << y1
<< "Xmax : "
<< theRect.xMax()
<< "-->" << x2
<< ", Ymax: "
<< theRect.yMax()
<< " -->" << y2
<< std::endl;
#endif
return QgsRect(x1, y1, x2 , y2);
#0 0xffffe410 in ?? ()
#1 0xbfffdcb8 in ?? ()
#2 0x00000006 in ?? ()
#3 0x4129e529 in abort () from /lib/tls/libc.so.6
#4 0x41223c25 in __cxxabiv1::__terminate () from /usr//lib/libstdc++.so.5
#5 0x41223c62 in std::terminate () from /usr//lib/libstdc++.so.5
#6 0x41223da2 in __cxa_throw () from /usr//lib/libstdc++.so.5
#7 0x080ff9b5 in QgsCoordinateTransform::inverseTransform (this=Variable
"this" is not available.
) at qshared.h:50
#8 0x080f8d9a in QgsMapCanvas::render (this=0x83efb10, theQPaintDevice=0x0)
at memory:271
Procrastination
"Hard Work Often Pays Off After Time, but Laziness Always Pays Off Now."
