[Gdal-dev] Re: OGR Spatial Questions
Peter von Gaza
pvg at pixelmapper.com
Tue Jan 18 13:29:11 EST 2005
Frank,
Thanks! Everything works now. I was hoping for a simple solution.
I'm just starting to work with your OGR projection code but have
to say that I am VERY impressed how easily I was able to compile
an "ogr.dll" in Borland BCB5 and get it link and working in my
program. Amazing stuff.
Thanks,
Peter
Frank Warmerdam wrote:
>>Works fine. Then I load a geotiff and try the following:
>> char *pszProjection = GTIFGetOGISDefn(gtif, &defn );
>> // string looks like it should
>> OGRSpatialReference oSRS;
>> OGRErr i = oSRS.SetProjection( pszProjection );
> Here lies your problem. The SetProjection() method is used to
> set the projection method to be used, such as "Transverse_Mercator".
> To import a complete WKT coordinate system definition you should
> use the importFromWkt() method.
> eg.
> char *pszProjectionCopy = pszProjection;
> if( oSRS.importFromWkt( &pszProjectionCopy ) != OGRERR_NONE )
> return;
> The setting up of a duplicate pointer to the WKT definition
> is because importFromWkt() updates to pointer to point to the
> next character past the imported definition. The approach was
> intended to let me process WKT out of a larger string, but in
> practice I have never used that ability and the method has been
> clumsy to use (as above).
> Best regards,
