[Gdal-dev] ogr.py - managing the lifetime of Geometry and Feature objects
Frank Warmerdam fwarmerdam at gmail.com
Sat Jan 22 01:18:56 EST 2005
Folks,
With encouragement (aka browbeating) from Howard Butler I have
implemented logic in the python bindings of the OGRFeature and
OGRGeometry classes so that instances of ogr.Geometry and ogr.Feature
keep track whether they "own" the associated C++ object.
When the python object is destroyed (it's reference count drops to
zero) it will destroy the C++ object if it still owns it.
So, if you call Layer.GetNextFeature() to get a feature, it will be
owned by you, and when the feature is no longer referenced from
Python it will be automatically destroyed.
You are still free to explicitly destroy with the Destroy() method,
in which case the "ownership" flag is cleared so no extra attempt
will be made to destroy it in the python object destructor.  So old
style "managed lifetimes" code will still be OK.
For geometries something similar is done.
These changes will only affect those using the Python bindings
and all old code should still work.  In the future you should not need
to explicitly Destroy() features or geometries.
Best regards,
