[Gdal-dev] question on gdal_translate
francesco
francesco.pirotti at unipd.it
Sat Jan 22 07:15:08 EST 2005
Hello,
Thought this might help.
Following this question (which I include below) which Frank kindly answered
a while ago, I found that escaping the quote characters permits the
gdal_translate utility to read an image from another disk.
So the example in the mail below would be:
HDF4_SDS:ASTER_L1B:\"C:\image\":10
instead of
HDF4_SDS:ASTER_L1B:"C:\image":10
the whole command was:
D:\Documenti\work\programmazione\python\gaia/bindir/gdal_translate.exe
-srcwin 0 0 404 310 -outsize 100% 100% -b 5 -ot Byte -scale
HDF4_SDS:ASTER_L1B:\"C:\treviso\001\":8 newfile.tif
Cheers!
Francesco Pirotti
CIRGEO
Centro Inderdipartimentale di Cartografia
Fotogrammetria, Telerilevamento e S.I.T.
Università di Padova
Viale dell'Università 16 - Legnaro - PD
www.cirgeo.unipd.it
tel. +39.328.2126861
tel. +39.049.827.2522/2688
fax. +39.049.8272686
At 04.53 17/12/2004, Frank Warmerdam wrote:
>On Tue, 14 Dec 2004 19:59:59 +0100, francesco
><francesco.pirotti at unipd.it> wrote:
> > Hello,
> > is there a way to select a subdataset of an image which is in another
> > disk? My partition has gdal stuff in D:\ and the image is in C:\
> > I cannot use gdal_translate using a subdataset such as:
> > It is ok if my image is in another folder in the same disk, then I can use
> > the ../ format to go backwords in the directory. But no way to go in the
> > other disk. Is there a trick?
>Francesco,
>This is a bug in the HDF driver. I have created a bug report on the issue at:
> http://bugzilla.remotesensing.org/show_bug.cgi?id=716
>The problem is presumably because we parse some aspects of the string
>based on colons. Hopefully with some work the driver can be altered to
>handle this gracefully especially since the drive specifier is in a
>quoted portion
>of the name.
>PS. Andrey reports he is hoping to do some substantial work on the HDF
>driver in January, so with luck this and a variety of other HDF related issues
>can be resolved then.
>Best regards,
>I set the clouds in motion - turn up | Frank Warmerdam, warmerdam at pobox.com
>light and sound - activate the windows | http://pobox.com/~warmerdam
>and watch the world go round - Rush | Geospatial Programmer for Rent
