[Gdal-dev] RE: OGR GML output
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Mon Jan 31 09:30:55 EST 2005
> On Wed, 26 Jan 2005 21:52:55 -0500, Kralidis,Tom [Burlington]
> <Tom.Kralidis at ec.gc.ca> wrote:
> > Hi,
> > Using under GDAL 1.2.5, I converted a shapefile to a GML document,
> > i.e.:
> > ogr2ogr -f GML out.gml hydroshedg.shp
> > ...and have some comments / suggestions w.r.t. the output GML:
> > .xsd file generated:
> > - http://schemas.cubewerx.com/schemas/gml/2.1.2/feature.xsd
> is used as
> > the schemaLocation for the GML import. Suggest changing to
> > http://schemas.opengeospatial.net/gml/2.1.2/feature.xsd
> Tom,
> Updated the schemaLocation.
> > - the ogr namespace in the .xsd and the .gml document
> differ. Should
> > be the same (suggest http://gdal.maptools.org/ogr/)
> I have changed them both to be http://ogr.maptools.org/.
> > .gml file generated:
> > - the root element should add an attribute which points to the .xsd
> > file generated (i.e.
> xsi:schemaLocation="http://gdal.maptools.org/ogr/
> > ./out.xsd"
> There is a line that reads:
> xsi:schemaLocation=". out.xsd"
> I assume that is the correct way to refer to an out.xsd file
> in the same directory as the file referencing it ... isn't
> it? I can't very well refer to http://gdal.maptools.org/ogr
> as being the location since it will never be there, can I?
The format of xsi:schemaLocation is:
xsi:schemaLocation="[namespace] [.xsd file]"
...so the first arg (namespace) is okay. The .xsd can be local or on
another box via http.
> > - suggest a default namespace in the root element (i.e.
> > xmlns="http://gdal.maptools.org/ogr/"), thus negating the
> requirement
> > to prefix elements with "ogr".
> I have added this. Is there any harm in including the "ogr"
> prefixes on elements? I think it makes things clearer.
OK. My recommendation was based on the norm I see out there (default
namespace'd XML docs as opposed to explicitly referred to prefixes).
Should be okay either way, I think.
> > I'd be willing to help out with this in terms of testing and XML /
> > Schema design.
> I have also committed the changes I made last week to bring
> the OGR GML support into line with the 3L0 (GML 3 Level 0)
> profile document with the exception that I still refer to the
> GML 2.1.2
> feature.xsd.
> If you get a chance to try what is in CVS now, I would
> appreciate additional feedback. I'm afraid XML (especially
> stuff related to
> XML Schema and namespaces) is not my forte so help is
> appreciated.
OK, is there a Windows binary of latest CVS by any chance out there
being generated?
