[Gdal-dev] gdalwarp and satellites
Frank Warmerdam
fwarmerdam at gmail.com
Mon Jan 31 11:52:40 EST 2005
On Sat, 29 Jan 2005 05:27:52 -0800 (PST), gronnen <gronnen at yahoo.com> wrote:
> Hello!
> I have satellite images of eumetsat. This satellite
> is above the earth at longitude=0, and latitude=0.
> I know the height of the satellite and its
> fov. What projection and parameters I should
> use in gdalwarp ? is it possible ?
Gronnen,
Sorry, I'm not to sure how to work out image geo-location information from
satellite platform position and direction. This can be an involved process.
However, if you can derived lat/long location information for a grid
of control points on the image, you can associate them with the image
as GCPs (perhaps using gdal_translate) and then use gdalwarp to warp
the image to some desired projection. Note that you might want to use
Thin Plate Spline transformations if the image is a substantial chunk of
the earth and so suffers from curveture effects that wouldn't be handled
well by polynomials.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
