[Gdal-dev] VRT Dataset problem
Chris Hodgson
chodgson at refractions.net
Wed Jul 6 18:00:21 EDT 2005
I'm trying to write a VRT file which tiles several images together -
each image is a google maps tile :)
I think my problem is that I need to define the color table for the
vrtrasterband since I have defined it as "palette" ColorInterp. However,
the individual tile images do not have identical color palettes (though
I suspect they have very nearly the same colors, just at different table
indexes). Is there a way, with a vrt file, to tell gdal to map the
colors from the table into a normal RGB colorspace?
Anyways, the symptom is that when I do a galinfo on the vrt file, I get
a segfault:
$ gdalinfo test.vrt
Driver: VRT/Virtual Raster
Size is 512, 512
Coordinate System is `'
Origin = (0.000000,0.000000)
Pixel Size = (0.35156250,0.17578125)
Corner Coordinates:
Upper Left ( 0.0000000, 0.0000000)
Lower Left ( 0.0000000, 90.0000000)
Upper Right ( 180.0000000, 0.0000000)
Lower Right ( 180.0000000, 90.0000000)
Center ( 90.0000000, 45.0000000)
Band 1 Block=128x128 Type=Byte, ColorInterp=Palette
Segmentation fault
My tiles look like this (yes they have unusual names):
$ gdalinfo mt_v=w2.4\&x=1\&y=1\&zoom=15
Driver: GIF/Graphics Interchange Format (.gif)
Size is 256, 256
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 256.0)
Upper Right ( 256.0, 0.0)
Lower Right ( 256.0, 256.0)
Center ( 128.0, 128.0)
Band 1 Block=256x1 Type=Byte, ColorInterp=Palette
NoData Value=144
Color Table (RGB with 256 entries)
0: 242,239,233,255
1: 153,179,204,255
My VRT file looks like this (essentially created by hand):
<VRTDataset rasterXSize="512" rasterYSize="512">
<GeoTransform>0, 0.3515625, 0.0, 0, 0.0, 0.17578125</GeoTransform>
<VRTRasterBand dataType="Byte" band="1">
<ColorInterp>Palette</ColorInterp>
<SimpleSource>
<SourceFilename
relativeToVRT="1">mt_v=w2.4&x=0&y=0&zoom=15</SourceFilename>
<SourceBand>1</SourceBand>
<SrcRect xOff="0" yOff="0" xSize="256" ySize="256"/>
<DstRect xOff="0" yOff="0" xSize="256" ySize="256"/>
</SimpleSource>
<SimpleSource>
<SourceFilename
relativeToVRT="1">mt_v=w2.4&x=0&y=1&zoom=15</SourceFilename>
<DstRect xOff="0" yOff="256" xSize="256" ySize="256"/>
</SimpleSource>
<SimpleSource>
<SourceFilename
relativeToVRT="1">mt_v=w2.4&x=1&y=0&zoom=15</SourceFilename>
<DstRect xOff="256" yOff="0" xSize="256" ySize="256"/>
</SimpleSource>
<SimpleSource>
<SourceFilename
relativeToVRT="1">mt_v=w2.4&x=1&y=1&zoom=15</SourceFilename>
<DstRect xOff="256" yOff="256" xSize="256" ySize="256"/>
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
