[Gdal-dev] Large file support under Tiger?
Frank Warmerdam fwarmerdam at gmail.com
Tue Jul 26 23:21:59 EDT 2005
On 7/26/05, Jonathan Greenberg <jgreenberg at arc.nasa.gov> wrote:
> Hi there, I've finally gotten a hold of Tiger and can't seem to get GDAL
> compiled with large file i/o, which was supposed to be included in the 10.4
> release.  I've tried adding the compiler flags:
> CPPFLAGS=-D_FILE_OFFSET_BITS=64
> CXXFLAGS=-D_FILE_OFFSET_BITS=64
> CFLAGS=-D_FILE_OFFSET_BITS=64
> But the configure script still says "Large file io... no"
> Thoughts?  I honestly bought Tiger just so I could get starspan and grass
> (which uses GDAL) working with > 4gb files, so I'm eagerly awaiting any
> ideas...
Jonathan,
Are you using GDAL 1.2.6 or GDAL-CVS?  GDAL-CVS should support
large files on 10.3 without any special configuration options, but this
was added post-1.2.6.
Best regards,
