[Gdal-dev] Re: scanned maps for mosaicking
Andrey Kiselev
dron at ak4719.spb.edu
Tue Jun 7 13:37:29 EDT 2005
On Tue, Jun 07, 2005 at 11:58:22AM +0000, Juan Cicuéndez wrote:
> > The simplest solution is to convert all your scans in the 24-bit RGB
> > format. You can do that with the tiff2rgba utility from the libtiff
> > package. Be ready that resulting images will be larger than original
> > ones, but not too much if you will use compression.
> I tried to convert the imagery from normal tiff with colour table to
> RGB tiff with tiff2rgba. Somehow I obtain 4-banded files. Should it
> not be 3 bands instead? Is this normal?
Yes, that is normal (default) behaviour of the tiff2rgba utility. You
need the -n switch to disable the forth channel generation. The
following is taken from the tiff2rgba manual:
-n Drop the alpha component from the output file, producing
a pure RGB file. Currently this does not work if the -b
flag is also in effect.
> Besides my program used to includ a line
> fileInfoArr[i] = new FileInfo(filename, oTargetSRS, temp_dir);
> that fails now with the RGB tiff files; this might be related to my
> previous comment.
Sorry, but I didn't understand what that line does. Could you describe
your problem in more details?
Best regards,
Andrey
Andrey V. Kiselev
Home phone: +7 812 5970603 ICQ# 26871517
