[Gdal-dev] Geometry Types
Frank Warmerdam
fwarmerdam at gmail.com
Wed Jun 8 16:42:28 EDT 2005
On 6/7/05, Michele Sanges <michele.sanges at otomelara.it> wrote:
> Hi all,
> in file 'ogr_core.h' is defined this enum type:
> typedef enum
> wkbUnknown = 0,
> wkbPoint = 1,
> wkbLineString = 2,
> wkbPolygon = 3,
> wkbMultiPoint = 4,
> wkbMultiLineString = 5,
> wkbMultiPolygon = 6,
> wkbGeometryCollection = 7,
> wkbNone = 100,
> wkbLinearRing = 101,
> wkbPoint25D = 0x80000001,
> wkbLineString25D = 0x80000002,
> wkbPolygon25D = 0x80000003,
> wkbMultiPoint25D = 0x80000004,
> wkbMultiLineString25D = 0x80000005,
> wkbMultiPolygon25D = 0x80000006,
> wkbGeometryCollection25D = 0x80000007
> } OGRwkbGeometryType;
> Where can i find the description of any of such geometry types, in
> particular the 25D extensions?
Michele,
What sort of information were you looking for? Many of these codes
correspond in a relatively obvious way to classes derived from OGRGeometry
and can be tracked from:
http://www.gdal.org/ogr/classOGRGeometry.html
The 25D version are the normal 2D versions, but with a Z value for each vertex.
The geometry classes are based on the OpenGIS Simple Features geometry
model, so looking at the corresponding OGC spectifications could be useful.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
