[Gdal-dev] Compile problem on AIX5.1
alessandro.peloso alessandro.peloso at portici.enea.it
Thu Jun 9 05:22:06 EDT 2005
Hi list,
I need to compile gdal (version 1.2.6) on IBM AIX 5.1.
Someone can help me to workaround the well known bug#:498 ( --> libtiff
bug#:39)?
These are some output from my system:
%oslevel -r
 5100-04
%gcc -v
Reading specs from
/opt/freeware/lib/gcc-lib/powerpc-ibm-aix5.1.0.0/3.3.2/specs
Configured with: ../configure --with-as=/usr/bin/as
--with-ld=/usr/bin/ld --disable-nls --enable-languages=c,c++
--prefix=/opt/freeware --enable-threads
--enable-version-specific-runtime-libs --host=powerpc-ibm-aix5.1.0.0
Thread model: aix
gcc version 3.3.2
So far i tried:
-remove the patch to tiff.h;
-building without libtool;
-compile with VisualAge cc and gcc;
but with no success...
Any help will be appreciated.
Thanks
Alessandro Peloso
ENEA CR Portici
_______________________________________
MAIL SCANSIONATA DA ANTIVIRUS GATEWAY
(Outbound)
.#ENEA#.
